- 28 Feb 2007
Hey, this may be a very simple question, as it should be, but here goes.
So i have a hedge cutter with a motor of stated power consumption of 350W, I presume that in normal use the motor would not pull the full 350W constantly?
Therefore......how would you calculate the required battery capacity for a 24v battery?
P=VI
V=24v
I=?
P= < 350W
So if the motor was pulling 350W, the current drawn would be:
I=P/V
I = 14.6A
How can that be right? surely the battery wouldnt deliver that many amps?
also for the battery to last one hour, it would have to be 14.6Ah, which would be massive..........
So basically, is my physics correct and if so what would be a reasonable average amount of power drawn by a small hedge trimmer?
Thanks
DIFFEY
P=VI
V=24v
I=?
P= < 350W
I=P/V
I = 14.6A
Thanks
DIFFEY
Your calculations are correct by the way.
