I'm in a bit of a dilemma and need some advice please. I can't make my mind up between the 2 radiators below please if you can let me know which will perform better keeping in mind the thickness of the radiators and size..
Alphacool XT45 280mm Radiator (45mm thick) will have 2x fans in push
XSPC EX420 420mm Radiator (36mm thick) Will have 3x fans in push
As you can see above the Alphacool radiator is 280mm in size but is 45mm thick while the XSPC one is only 36mm thick but is bigger in size at 420mm plus will have one extra fan. Depending on what radiator I go for one will have 2x fans and the other one will have 3x fans but the fans will be the same used on both radiators The Akasa Viper AK-FN063 140mm fans
