help fallout 3 dlc
4 Dec 2002
ilkeston derbys
hi
just set up an account on gfwl which was a nightmare . ive d/loaded point lookout but i cant find it on my pc . ive looked in the default folder and nothing . i changed default folder to desktop , redownloaded it and still nothing .
help please
you shouldnt technicaly need to move anything to play the new DLC on fallout, but if you do want to move the files, they are in some hiddern away folders deep down in the user account folder, however fallout's wiki does tell you where they are held, if you want to have alook on that site.
hi
help please
You need to install Fallout 3 on the same drive letter as Windows otherwise it may not work at all due to poor scripting by Bethesda.
This is the official forum for GFWL related issues moderated by MS:
http://forums.gamesforwindows.com/44.aspx
Otherwise try Bethesda:
http://www.bethsoft.com/bgsforums/index.php?showforum=50
right ive started the game up and its come up on the map
should have done that in the first place.
thanks again
