Building my first PC and in the initial power up phase. All looking good but the four case fans aren’t firing up - they came pre installed in the XPG case and I have connected the power to the PSU - which seems ok as its running the gpu and motherboard. Motherboard is a tomahawk x570 so has onboard rainbow and rgb stuff. I just want to get the fans working. I’ve also swapped things around and the sata drive is working etc. There aren’t any cables that I can see that would connect to the motherboard just the extenders and daisy chains. I think the fan wires all come pre connected ready to go so assuming it’s a power issue but there is nothing I can find online that gives any clarity - especially not XPG. I assume I can buy a controller and connect it up to the motherboard if I am stuck as I don’t want to tear it all down again Any advice would be welcome thanks ps tried to attach a pic of the connector to the psu there aren’t any other obvious ones from the front panel ..
