- 8 Dec 2006
I've been out of the scene for a good few years and have decided it's time to dive back in. This system will mainly be used for gaming and browsing, but will also be used as a 'back-end' to a couple of Xboxes running 'Xbox Media Center' and for streaming HD video to a Xbox 360 once I decide the time is right for Vista. I already have a nice 1650x1080 monitor and a mouse, keyboard, speakers etc.
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit
BFG GeForce 8800 GTS OC 640MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
Creative Sound Blaster X-Fi Xtreme Music 7.1 Soundcard - OEM
2 x Western Digital Caviar SE16 320GB 3200KS SATA-II 16MB Cache [Going to be run in RAID 0]
Samsung SH-W183 18x18 DVD±RW Serial ATA Dual Layer ReWriter (Black) - OEM
Lian-Li PC-7 PLUS Aluminium Midi-Tower Case - Black
Antec TruePower Trio 650W PSU
Noctua NF-S12 800RPM 120mm Silent Case Fan - 3 Pin
Noctua NF-R8 80mm Silent Case Fan - 3 Pin
Does anything there stand out as a bad choice? Any better choices in a similar price bracket?
Is that soundcard worthwhile? I remember onboard sound -used- to be awful... Has anything changed there? Will I see a difference in gaming performance between that and the onboard sound? The PC will be hooked up to a mid-range 2 channel stereo system. The media centre stuff will -only- be piping files to other rooms where dedicated AV gear does all of the work, so no need for a fancy card for that.
I've heard the stock fans on the PC-7 can be pretty loud, hence those Noctuas. Worth the extra few quid?
Any advice will be -hugely- appreciated... I've tried to do my research but things have moved on so far since I last specced a machine it's terrifying!
