Help finding a 17" Laptop..
29 Nov 2002
Midlands. UK
My dad is planning to work from a Boat he owns and needs a laptop he car charge off a 12volt car-style charger.. So im looking to find a new laptop for him..
Needs to be:
  • Fairly Compact / Lightweight
  • Has a 12V charger option
  • Good battery life between chargers.
Dosnt need to be:
  • Hugely powerfull i3 max..
  • Anything fancy
Budget might help narrow one down, but a 17"er is not going to be compact or lightweight. All laptops are 19-20v so you would just need a 12 to 19v adapter.
Well id say about £600 is a good figure go on for now..
I appreciate that 17" laptops are generally pretty big, but consider that my dads old centrino DELL Inspiron weighed a small ton and was about 1.5" thick anything modern is thiner..
My point being to emphasise on the weight / compact design than the internal workings.. he only does a bit of basic CAD work, Word and Office apps...
Lenovo IdeaPad G770
Part Number: M533QUK
Stock Code: 6563566
Intel® Core™ i3-2330M Dual Core Processor, 17.3" HD Screen, Windows 7 Home Premium Edition, 8GB RAM, 750GB HDD, DVD Rewriter, Dedicated Graphics Ati 6650,
£549
or £619 for the i5 version.
Nothing else better for the money imo. A Dell XPS L702 may come up better for games but reliability and build quality is won by the Lenovo ten times over.
Lenovo IdeaPad G770
Stock Code: 6563566
£549
Looks like just the thing for me.. 2.9kgs which isnt tooo bad.. bit lighter than the 17" MBP's currently on the market. So i doubt ill find much lighter.. Plus they i have found it for £450 with 4GB ram..
Make sure it has the dedicated graphics though, the cheaper ones don't,unless you don't need it of course.
