Hi all,
I want to get a new CPU cooler and CPU already running fairly hot (constant 54C on full load). Not worried about it, as normal speeds that temp is fine, but planning on maybe doing some overclocking and obviously need to get a lower tempt to start thinking about overclocking.
I have a AMD Phenom II X6 Six Core 1090T Black Edition, on a ASUS M4A89GTD PRO/USB3ATX - AMD 890GX motherboard in a Thermaltake VK60001W2Z Element S Case.
Just looking for some suggestions on mid-range and on top-range CPU coolers that will work and fit. Found a few threads of the actual overclocking bit; it’s choosing a cooler that will work well that I need help with.
Thanks in advance, if anything I've forgotten to post just ask!
Thank you,
Thank you,
