- 12 Aug 2013
Hi, all. I am sure you get this posted a lot but I am struggling to find a headset as when I find a set of reviews on one headset, there is always at least one experience of a technical fault that drags down the rating.
I currently have the turtle beach X12's but have had them for a couple of years now and I would like to find a better headset. I don't want to spend an extortionate amount (a few hundred) but would be willing to push to around £100 for a good set. I use it mainly for gaming and will be using it for PC, Xbox One and PS4.
What is the best headset you recommend as, without testing them myself, I'm finding it hard to judge? If you have experienced the headset yourself, that would be even better.
