Right I'm in the market for a new office chair.
I have a budget of around £500 upper limit, but I'm not sure what to get.
So i'm after some recommendations. As it's so hard to find any review or info on high ish end chairs, apart from the Herman miller aeron.
I have been looking at the aeron. But i'm a little unsure as I have been reading the bar at the front edge of the chair can be quite annoying, and can cut the circulation off.
I also quite like the looks of http://discountdesking.co.uk/office-chairs-delivered-in-48-hours/deluxe-seating/rimini/prod_511.html. But i'm unsure if it will be any good as most days it tends to get 8+ hours use. And it thinks its mostly built for design.
And finally I have been looking at some on http://www.officechairsuk.com/acatalog/Task.html does anyone use any of these chairs and can comment on their comfort levels.
Thanks in advance.
Thanks in advance.
