Help finding AA battery pack
30 Jun 2009
Surrey, England
Hey GD,
Bit stuck on this one and was wondering if anyone here would know where I could get one of the below:
Holds 2 x AA batteries and has a 2 PIN connector.
Its for something I got from the US so wanted to see if it was possible to source one from the UK first before going back to the company I brought it off.
Also if anyone knows of a rechargeable one (like RC packs) that would be fine as well.
you could use any battery pack/holder that is the same voltage just cut the connector off that one and stick it on another or find one with the same connector.
try hobbyking
whats it from anyway?
Light up hoodie for the misses :D
Although I've just realised that the button switches between 3 modes of flashing :(
oh if it has 3 modes of flashing theres probably something controlling the on/off pulses or whatever.
if you added a regular battery pack the lights would probably just be on/off
the led driver is prob built into that battery holder aswell.
you could probably get it repaired at an electronics shop or you could try yourself it might just be a lose wire
I've had a look myself but can't see anything missing or loose.
If I could just get the battery pack without the 3 modes I wouldnt really mind, just need to find the right one :)
