Help finding BSOD/Reboot culprit
30 Dec 2011
Hi all,
Im after some help. Since being built 2 years ago my rig has suffered from seemingly random reboots. Only now have I decided to actually get this sorted once and for all.
I ran HOT CPU and got the below
000000| 0000 00000368 Sep, 03 - 23:34:20 | Startig Hot CPU Tester Pro 4.4.1
000001| 1012 00000368 Sep, 03 - 23:34:21 | Initializing DefectTrack Engine version 2.2.0
000002| 1010 00000368 Sep, 03 - 23:34:21 | Loading options...
000003| 1011 00000368 Sep, 03 - 23:34:21 | Reading system info...
000004| 0000 00000368 Sep, 03 - 23:34:23 | CPU: Intel(R) Core(TM) i5-3570K CPU @ 3.40GHz
000005| 0000 00000368 Sep, 03 - 23:34:23 | Speed: 3399MHz
000006| 0005 00000368 Sep, 03 - 23:34:23 | -1
000007| 0005 00000368 Sep, 03 - 23:34:23 | -1
000008| 0005 00000368 Sep, 03 - 23:34:23 | -1
000009| 0000 00000368 Sep, 03 - 23:34:23 | L1 Cache Size: -2KB
000010| 0000 00000368 Sep, 03 - 23:34:23 | L2 Cache Size: -1KB
000011| 0000 00000368 Sep, 03 - 23:34:23 | L3 Cache Size: -1KB
000012| 0000 00000368 Sep, 03 - 23:34:23 | Hyper-Threading: FALSE
000013| 0000 00000368 Sep, 03 - 23:34:23 | SMP: TRUE
000014| 0000 00000368 Sep, 03 - 23:34:23 | Scanning SMBIOS...
000015| 0000 00000368 Sep, 03 - 23:34:23 | Could not read SMBIOS data
000016| 0000 00000368 Sep, 03 - 23:34:23 | Total Physical Memory: -1 bytes
000017| 0000 00000368 Sep, 03 - 23:34:23 | Availabe Physical Memory: -1 bytes
000018| 0000 00000368 Sep, 03 - 23:34:23 | Total Virtual Memory: -131072 bytes
000019| 0000 00000368 Sep, 03 - 23:34:23 | Availabe Virtual Memory: -99041280 bytes
000020| 0000 00000368 Sep, 03 - 23:34:23 | Operating System: Windows Server 2007 Home Premium Service Pack 1
000021| 0156 00000368 Sep, 03 - 23:34:23 | Setting Process Priority...
000022| 1017 00000368 Sep, 03 - 23:35:43 | Changing Log File Path...
000023| 1111 00000368 Sep, 03 - 23:36:54 | Diagnostic has started
000024| 1112 00000368 Sep, 03 - 23:36:54 | Test Duration: 06:00:00
000025| 1113 00000368 Sep, 03 - 23:36:54 | Diagnostic Method: Sequential
000026| 1114 00000368 Sep, 03 - 23:36:54 | Error Handling: Ignore and Continue
000027| 1115 00000368 Sep, 03 - 23:36:54 | Hyper-Threading: Disabled
000028| 0010 00000368 Sep, 03 - 23:36:54 | -Complex Matrix : Disabled
000029| 0011 00000368 Sep, 03 - 23:36:54 | --Thread Priority: THREAD_PRIORITY_NORMAL
000030| 0011 00000368 Sep, 03 - 23:36:54 | --Matrix Size: 3,000x3,000
000031| 0011 00000368 Sep, 03 - 23:36:54 | --Matrix Data Type: Double
000032| 0010 00000368 Sep, 03 - 23:36:54 | -Calculating Pi : Enabled
000033| 0011 00000368 Sep, 03 - 23:36:54 | --Thread Priority: THREAD_PRIORITY_NORMAL
000034| 0011 00000368 Sep, 03 - 23:36:54 | --Pi Iterations: 10,000
000035| 0010 00000368 Sep, 03 - 23:36:54 | -Sorting Algorithms : Enabled
000036| 0011 00000368 Sep, 03 - 23:36:54 | --Thread Priority: THREAD_PRIORITY_NORMAL
000037| 0011 00000368 Sep, 03 - 23:36:54 | --Insertion Sort: Enabled
000038| 0011 00000368 Sep, 03 - 23:36:54 | --Shell Sort: Enabled
000039| 0011 00000368 Sep, 03 - 23:36:54 | --Merge Sort: Enabled
000040| 0011 00000368 Sep, 03 - 23:36:54 | --Heap Sort: Enabled
000041| 0011 00000368 Sep, 03 - 23:36:54 | --Quick Sort: Enabled
000042| 0011 00000368 Sep, 03 - 23:36:54 | --CArray Quick Sort: Enabled
000043| 0011 00000368 Sep, 03 - 23:36:54 | Sorting Array Size: 100,000
000044| 0010 00000368 Sep, 03 - 23:36:54 | -Prime Test : Enabled
000045| 0011 00000368 Sep, 03 - 23:36:54 | --Thread Priority: THREAD_PRIORITY_NORMAL
000046| 0011 00000368 Sep, 03 - 23:36:54 | --Iterations: 100,000
000047| 0010 00000368 Sep, 03 - 23:36:54 | -Fast Fourier Transforms : Disabled
000048| 0011 00000368 Sep, 03 - 23:36:54 | --Thread Priority: THREAD_PRIORITY_NORMAL
000049| 0010 00000368 Sep, 03 - 23:36:54 | -Chipset : Disabled
000050| 0011 00000368 Sep, 03 - 23:36:54 | --Thread Priority: THREAD_PRIORITY_NORMAL
000051| 0010 00000368 Sep, 03 - 23:36:54 | -L1 Cache : Disabled
000052| 0011 00000368 Sep, 03 - 23:36:54 | --Thread Priority: THREAD_PRIORITY_NORMAL
000053| 0010 00000368 Sep, 03 - 23:36:54 | -L2 Cache : Disabled
000054| 0011 00000368 Sep, 03 - 23:36:54 | --Thread Priority: THREAD_PRIORITY_NORMAL
000055| 0010 00000368 Sep, 03 - 23:36:54 | -Memory : Enabled
000056| 0011 00000368 Sep, 03 - 23:36:54 | --Thread Priority: THREAD_PRIORITY_NORMAL
000057| 0010 00000368 Sep, 03 - 23:36:54 | -HD : Enabled
000058| 0011 00000368 Sep, 03 - 23:36:54 | --Thread Priority: THREAD_PRIORITY_NORMAL
000059| 0010 00000368 Sep, 03 - 23:36:54 | -MMX : Enabled
000060| 0011 00000368 Sep, 03 - 23:36:54 | --Thread Priority: THREAD_PRIORITY_NORMAL
000061| 0010 00000368 Sep, 03 - 23:36:54 | -SSE : Disabled
000062| 0011 00000368 Sep, 03 - 23:36:54 | --Thread Priority: THREAD_PRIORITY_NORMAL
000063| 0010 00000368 Sep, 03 - 23:36:54 | -SSE2/SSE3 : Disabled
000064| 0011 00000368 Sep, 03 - 23:36:54 | --Thread Priority: THREAD_PRIORITY_NORMAL
000065| 0010 00000368 Sep, 03 - 23:36:54 | -3DNow! : Disabled
000066| 0011 00000368 Sep, 03 - 23:36:54 | --Thread Priority: THREAD_PRIORITY_NORMAL
000073| 1026 00000e54 Sep, 03 - 23:36:54 | Starting Calculating Pi Module on CPU 1
000076| 1038 000003e8 Sep, 03 - 23:36:54 | Starting Memory Mdoule on CPU 1
000068| 1028 00000aa8 Sep, 03 - 23:36:54 | Starting Sorting Algorithms Module on CPU 0
000075| 1030 00000534 Sep, 03 - 23:36:54 | Starting Prime Test Module on CPU 1
000067| 1026 00000c60 Sep, 03 - 23:36:54 | Starting Calculating Pi Module on CPU 0
000074| 1028 00000a44 Sep, 03 - 23:36:54 | Starting Sorting Algorithms Module on CPU 1
000080| 1028 00000a70 Sep, 03 - 23:36:54 | Starting Sorting Algorithms Module on CPU 2
000079| 1042 00001174 Sep, 03 - 23:36:54 | Starting MMX Module on CPU 1
000077| 1040 00001330 Sep, 03 - 23:36:54 | Starting HD Module on CPU 1
000083| 1040 000011dc Sep, 03 - 23:36:54 | Starting HD Module on CPU 2
000078| 1026 000011f0 Sep, 03 - 23:36:54 | Starting Calculating Pi Module on CPU 2
000081| 1030 00001338 Sep, 03 - 23:36:54 | Starting Prime Test Module on CPU 2
000071| 1042 000010e8 Sep, 03 - 23:36:54 | Starting MMX Module on CPU 0
000069| 1030 000000fc Sep, 03 - 23:36:54 | Starting Prime Test Module on CPU 0
000070| 1038 00000504 Sep, 03 - 23:36:54 | Starting Memory Mdoule on CPU 0
000072| 1040 000000cc Sep, 03 - 23:36:54 | Starting HD Module on CPU 0
000082| 1038 00000f68 Sep, 03 - 23:36:54 | Starting Memory Mdoule on CPU 2
000085| 1042 0000136c Sep, 03 - 23:36:54 | Starting MMX Module on CPU 2
000086| 1028 000012e0 Sep, 03 - 23:36:54 | Starting Sorting Algorithms Module on CPU 3
000088| 1038 00001118 Sep, 03 - 23:36:54 | Starting Memory Mdoule on CPU 3
000089| 1040 00000c40 Sep, 03 - 23:36:54 | Starting HD Module on CPU 3
000084| 1026 00001324 Sep, 03 - 23:36:54 | Starting Calculating Pi Module on CPU 3
000090| 1042 00000638 Sep, 03 - 23:36:54 | Starting MMX Module on CPU 3
000087| 1030 000013b4 Sep, 03 - 23:36:54 | Starting Prime Test Module on CPU 3
000091| 9999 00000aa8 Sep, 04 - 00:07:10 | Error:CPU 0: MFC QuickSort: Checksums do not match; a[206317] = 16868, a[206317] = 16869
000092| 0000 00000aa8 Sep, 04 - 00:07:11 | Minidump file saved at D:\Hot CPU Tester Pro 4 LE\\HCTSep04-000710.dmp
000093| 9999 00000a44 Sep, 04 - 02:27:54 | Error:CPU 1: MFC QuickSort: Checksums do not match; a[17178] = 1400, a[17178] = 1399
000094| 0000 00000a44 Sep, 04 - 02:27:55 | Minidump file saved at D:\Hot CPU Tester Pro 4 LE\\HCTSep04-022754.dmp
000095| 9999 00000a70 Sep, 04 - 02:49:09 | Error:CPU 2: MFC QuickSort: Checksums do not match; a[369249] = 30258, a[369249] = 30257
000096| 0000 00000a70 Sep, 04 - 02:49:10 | Minidump file saved at D:\Hot CPU Tester Pro 4 LE\\HCTSep04-024909.dmp
000097| 9999 000012e0 Sep, 04 - 03:55:01 | Error:CPU 3: MFC QuickSort: Checksums do not match; a[41487] = 3405, a[41487] = 3406
000098| 0000 000012e0 Sep, 04 - 03:55:02 | Minidump file saved at D:\Hot CPU Tester Pro 4 LE\\HCTSep04-035501.dmp
000099| 1009 00000368 Sep, 04 - 05:31:51 | Closing Hot CPU Tester Pro...
000100| 0000 00000368 Sep, 04 - 05:31:51 | ************ End of Session ************
Bluescreen view shows nothing when trying to open the dump file created above. About a year ago i ran memtest overnight and go no errors but ill rerun it tonight to check for RAM issues. I have used CCleaner over and over until nothing comes up, There is nothing showing in the device manager with the yellow "!". I'm not quite sure what else i can do to narrow the culprit.
Any help you guys can give would be great. Im not sure whether the CPU, MOBO or RAM needs replacing >.<
Also one thing of note, i had previously ran the same test as the above and it only failed on CPU0
000094| 0430 00000b94 Aug, 28 - 00:13:22 | File Exception error:The file could not be accessed:CPU 1: Access to an unnamed file was denied.
000095| 9999 00000ff4 Aug, 28 - 00:30:17 | Error:CPU 0: Checksums do not match; Matrix1 = -28115503932.879276, Matrix2 = -28115503932.883739
000096| 0000 00000ff4 Aug, 28 - 00:30:18 | Minidump file saved at D:\Hot CPU Tester Pro 4 LE\\HCTAug28-003017.dmp
000098| 1031 00000cf4 Aug, 28 - 03:22:29 | Ending Prime Test Module on CPU 3
000102| 1029 000010f4 Aug, 28 - 03:22:29 | Ending Sorting Algorithms Module on CPU 3
000100| 1039 00000c1c Aug, 28 - 03:22:29 | Ending Memory Module on CPU 3
000104| 1043 000011ec Aug, 28 - 03:22:29 | Ending MMX Module on CPU 3
000103| 1039 00000944 Aug, 28 - 03:22:29 | Ending Memory Module on CPU 2
000097| 1029 00000b38 Aug, 28 - 03:22:29 | Ending Sorting Algorithms Module on CPU 2
000099| 1031 00000f40 Aug, 28 - 03:22:29 | Ending Prime Test Module on CPU 2
000101| 1043 00001188 Aug, 28 - 03:22:29 | Ending MMX Module on CPU 1
000105| 1031 00000e18 Aug, 28 - 03:22:29 | Ending Prime Test Module on CPU 1
000108| 1041 00000bc0 Aug, 28 - 03:22:29 | Ending HD Module on CPU 2
000109| 1043 00001014 Aug, 28 - 03:22:29 | Ending MMX Module on CPU 2
000107| 1041 00000e70 Aug, 28 - 03:22:29 | Ending HD Module on CPU 3
000111| 1029 000011dc Aug, 28 - 03:22:29 | Ending Sorting Algorithms Module on CPU 1
000110| 1039 00000558 Aug, 28 - 03:22:29 | Ending Memory Module on CPU 1
000106| 1031 000004f4 Aug, 28 - 03:22:29 | Ending Prime Test Module on CPU 0
000113| 1027 00000b98 Aug, 28 - 03:22:29 | Ending Calculating Pi Module
000112| 1027 000010d4 Aug, 28 - 03:22:29 | Ending Calculating Pi Module
000114| 1027 0000138c Aug, 28 - 03:22:29 | Ending Calculating Pi Module
000115| 1043 000011d4 Aug, 28 - 03:22:30 | Ending MMX Module on CPU 0
000116| 1039 000011f4 Aug, 28 - 03:22:30 | Ending Memory Module on CPU 0
000117| 1029 00000e00 Aug, 28 - 03:22:30 | Ending Sorting Algorithms Module on CPU 0
000118| 1041 00000a38 Aug, 28 - 03:22:30 | Ending HD Module on CPU 0
000119| 1027 00001214 Aug, 28 - 03:22:30 | Ending Calculating Pi Module
000120| 1009 000011e4 Aug, 28 - 05:12:21 | Closing Hot CPU Tester Pro...
000121| 0000 000011e4 Aug, 28 - 05:12:21 | ************ End of Session ************
Also, 1 last thing, in trying to sort the problem out i have somehow removed all the older dump files >.<
Firstly, run at stock for a bit - see if that helps.
If not run with 1 stick or ram at a time. I've had faulty ram that has passed memtest
I did a quick 1 pass test on the sticks individually earlier and they both passed, which i figured they would.
I did a fresh install of windows on my SSD and im still having problems. On the plus side, i can see on blue screen view that its something to do with "ntoskrnl.exe" apparently. All of them have had this on there >.<
