Help Finding Good PC Case Choices
9 Dec 2006
@ManCave
Looking for the following:
: Hidden PSU
: Loads cable room
: ATX or ATX+
: 3 -4 GPU support
: SSD support big Bonus
: good air cooling 120mm+
To house X99 Setup
under say 350 pounds
Here is a selection of Corsair cases that would fit all of your criteria.
I have the 750D and it is a fantastic case, loads of room and great fan/rad support. I also love the vertically mounted SSD brackets they are great!
If you are going for a 2+ GPU system I would suggest putting it under water as those GPUs will generate some serious heat.
YOUR BASKET
1 x Corsair Obsidian 900D Super Tower Case (CC-9011022-WW) £274.99
1 x Corsair Graphite 760T Windowed Full Tower Gaming Case - White (CC-9011045-WW) £161.99
1 x Corsair Graphite 760T Windowed Full Tower Gaming Case - Black (CC-9011044-WW) £161.99
1 x Corsair Graphite 780T Full Tower Case - White (CC-9011059-WW) £144.95
1 x Corsair Graphite 780T Full Tower Case - Black (CC-9011063-WW) £139.99
1 x Corsair Obsidian 750D Full Tower Case - Black (CC-9011035-WW) £124.99
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Arctic White (CC-9011048-WW) £104.99
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Silver (CC-9011034-WLED) £104.99
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Black (CC-9011030-WW) £98.95
Total : £1,382.99 (includes shipping : £54.30).
Enthoo primo has the psu in a separate chamber. Makes for a very clean build. Good for air cooling and excellent water cooling support should you wish to go that route.
