Help finding info on my monitor
16 Jun 2014
Hey all,
I have a Aoc q3279wg5b monitor I bought from overclockers awhile back. This model doesn't appear on the aoc website! I'm looking for updated drivers, I just want to try to get my colours set up better but I've no idea what the settings mean in the OSD.
I've found a manual which suggests I should be able to set colour and image settings but they are greyed out. :(
IT seems I can't set up colours directly the Color setup icon is greyed out. :(
Anyone able to help me figure out where to find info?
Sometimes when a certain setting is enabled it greys out your colour settings.
This could be anything like,
Gamer modes in your OSD or HDR being enabled.
I would turn off other settings 1 by 1 and this might enable the colours to be changed.
Hey all,
It's probably greyed out because you have HDR enabled, same thing happens with my Alienware AW3423DWF, the settings are controlled by windows so you won't be able to edit them via the OSD.
