Help finding software - system tray panic button
2 Nov 2007
Hiya
I'm trying to find a piece of software that i had years ago - 2003-2004. It was a little green button that ran in the system tray. You double-clicked it and it cleaned your history, cleaned your temp files, recently opened docs and restarted explorer etc. It was on xp. I had a look in the useful software thread but nothing jumped out at me. I've no idea what it was called or who made it but i remember that it was freeware.
Can anyone help?
Many thanks
for it to work successfully it would need to be constantly updated....try crapcleaner instead. brilliant piece of software.
helps sort your registry out too.
