Help finding the right watercooling supported case
2 May 2015
Scotland
So I'm looking to support a full rigid build.
Must support at minimum 2x 240mm radiators
And a large reservoir.
I was looking at the Haf stackers from cooler master
However I can't get a hold of the middle part (935) just the top and bottom.
Aside from that any other suggestions as to which case I should get? Needs to be full ATX.
Preferably a case I can hide the pump etc.
Thanks
If you;re looking for a MATX the phanteks evolv can get a 240x45 in the front and 240x60 in the roof.
Cracking build quality too.
