Help finishing PC Spec please
28 Feb 2009
Just ordered these from OC:
OCZ Vertex Series 120GB 2.5" SATA-II Solid State Hard Drive (OCZSSD2-1VTX120G) 1 £349.99
Corsair 6GB DDR3 Dominator PC3-14400C9 1866MHz (3x2GB) Triple Channel DDR3 (TR3X6G1866C9DF) 1 £264.99
Intel Core i7 920 2.66Ghz (Nehalem) (Socket LGA1366) - Retail 1 £219.99
Asus P6T Deluxe Intel X58 (Socket 1366) PCI-Express DDR3 Motherboard 1 £211.99
Akasa AK-922 EVO Blue CPU Cooler (Socket 754/939/940/AM2/LGA775) 1 £26.99
OcUK Value 2.5" to 3.5" Hard Drive Adapter 1 £4.99
Am thinking of finishing with these:
Gainward GeForce GTX 295 1792MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail (GW-GTX295-1792) £477.24
(£414.99) £477.24
(£414.99)
Lian Li Armorsuit PC-P80B Aluminium Super Tower Case - Black (No PSU) £229.99
(£199.99) £229.99
(£199.99)
Corsair HX 1000W ATX2.2 Modular SLI Compliant Power Supply £195.98
(£170.42) £195.98
(£170.42)
Western Digital Caviar Green 1TB SATA-II 32MB Cache - OEM (WD10EADS) £83.94
(£72.99) £167.88
(£145.98)
Pioneer DVR-216BK 20x DVD±RW SATA Dual Layer ReWriter (Black) - OEM £19.54
(£16.99) £39.08
(£33.98)
Couple questions:
Any bottlenecking components there?
Do you advise buying any HDD Caddies for cooling or is the case good enough?
Any other recommendations on the rest of the build I gotta get?
Thanks guyz
This cooler won't fit on the i7 socket, it's for the previous generations of intel CPU's and also AMD.
I'd go for a 4870x2, pretty much the same performance, but for a lot less money.
(£170.42) £195.98
You don't need a 1000W PSU, way too much for that rig. Something around 700W will be enough, zalman, coolermaster, be quiet are all recommended
http://www.overclockers.co.uk/showproduct.php?prodid=CA-017-ZA&groupid=701&catid=123&subcat=1102
Thx for that, ordered:
Zalman CNPS9900-LED CPU Cooler (Socket 754/939/940/AM2/LGA775/LGA1366)
