HELP, first time w/cooling
Switch 810
Just over £130 - tons of room for water cooling and upgrades in the future. Good review on OC3D. And available in black and gunmetal as well.
decided, i'm keeping my case and just going to do a bit of modding to it :p
Cool, i am always interested in cases watercooled for modding. If you get any inspiration to do anything far out, make a project build log!
A general tip in 'light modding' that has helped my many loops: use of 'no more nails' Velcro tape. The stuff is insanely strong and eliminates the need to drill holes or anything to fit radiators/pumps/reservoirs anywhere. If you want to take your loop out, you can unscrew what is screwed down and just Velcro off everything Velcro'd down! It offers a slight bit of padding aswell and will take some vibrations that would normally make the case rattle a bit. This stuff is especially handy if you don't have a easy surface to make mounting holes and such.
Will do:) thanks for the tips mate will keep them in mind. I have already planned out a few things to it, just need to get some materials and takeover my dads garage for a few days and I will be sorted :p will take many pics and update the thread as I go.
