As title, spent an awful time fitting a corsair h55 and corsair n780 bracket to one on my 780Tis today. The instructions for both were absolutely appalling, but that's another story.
I'm pretty certain it's set up as it should be and making contact with the GPU die properly.
The connector is connected on the n780 bracket and GPU fan is spinning, and the 3 pin power connector from the pump is connected to a socket on my motherboard.
I ran a quick heaven bench and the GPU temp slowly crept up and up til the 80's at which point I quit. It's obvioulsy not working.
Ideas, quick??? How do I tell if the pump is working properly?
