- 26 Dec 2009
- North
Hi guys, got a free faulty laptop off my eldest sister which im trying to fix and give to my youngest sister.
Its a HP 530
Intel Core 2 Duo T5200 1.6Ghz
Intel 945GME Graphics
Intel 940 Chipset
2GB Ram
120GB HDD
As you can see its not a bad laptop, perfect for office etc. Anyhow so far have restored factory default, windows vista basic so is a fresh install.
Problem is after about 5mins of use screen gets all corrupted and freezes, have to restart.
I thought it was an over heating issue so opened up, cleaned, replaced tim on cpu and thermal pad on GPU. Now it works for 10-15mins before screen gets lines through it and freezes. I dont think its the CPU overheating as can run prime and temps are sub 80c, idles around 50c. Fan is spinning when doing something demanding.
This leads me to think its the GPU over heating as it works fine for 10-15mins and then screen gets corrupted, like major artifacting. When i restart straight away will only last a couple of mins, when i leave off to cool down will get another 10-15mins out of it.
Ive all ready replaced the thermal pad on it, so cant figure out what else i can do?
Its a HP 530
Intel 940 Chipset
2GB Ram
120GB HDD
and i've fixed quite a few laptops.
