- 3 Aug 2012
Hi all,
I’m after some advice and from reading through some of the threads on these boards this seems like a well-educated and helpful community, so I’m hoping someone will be able to help. Some history…
My PC was purchased June 2009 and I had it overclocked to around 4GHz with a single loop water cooling system on the CPU only. The pump broke twice: the first time I had it repaired (under warranty) and the second time I just gave up with the water cooling. I use the machine for work as well as gaming and couldn’t afford the downtime to send it off again.
I stripped out the res, pump, rad and tubing and replaced with air-cooling and reverted to the default setup in the BIOS (effectively the non-overclocked settings).
Main specs:
Asus P6T Deluxe V2 Intel X58 Chipset
i7 950 @ 3.06 8MB Cache (LGA1366)
12GB (6x2GB) PC16000 DDR3/1800mhz Triple Channel Memory (G.SKILL GBTD Series)
GTX295 1792MB 16X PCI Express
Creative Labs SB X-FI Titanium Fatal1ty Pro
80 GB Intel X25-M SSD
1.5TB SATA-II 3.0Gb/s 32M Cache 7200RPM
Tagan 1100W TG1100-BZ PipeRock Series Modular
Antec 1200 Case
*I have the spare PSU cables, and the b its and bobs left over from the mobo packaging.
The case is a little worse for wear now, there are spacers and bits missing and I have some loose cabling between PSU and mobo because the power to the mobo is quite temperamental. I’m way too embarrassed to post a picture of what I’ve done to what was once a great machine. Also, the USBs are very slow, and the eSATA connection doesn’t work.
I’d like to get it back in to a good state, and I think I need:
New case
New (bigger SSD) for OS
Will re-use the existing SSD as storage.
I’d also like to keep the mobo as it has a stable OC profile – but I’m unsure of what cooling I might need. I do not have the time, skill, or inclination to setup water cooling with separates.
I wanted to know if using a pre-built system such as http://www.overclockers.co.uk/showproduct.php?prodid=HS-006-AN&groupid=701&catid=2330&subcat=2262 will be good enough.
The GTX295 has now become very dirty and is running quite hot (85c under a bit of load). I guess I can just give this a good clean? I’ve seen some vids and blog posts about dismantling and replacing the TIM, so this might be an idea as opposed to a new card. I’m not a big gamer.
So, in summary:
What new case, can I just pick any?
New SSD
What cooling system so I can use the OC profile on the mobo
Budget around £300 or so and looking to do the job later this month as I have some time off.
Thanks in advance...
Main specs:
Antec 1200 Case
New case
So, in summary:
New SSD
