Hiya,
This is on a 1GB Asus 4850.
I've burned my fingers playing with Catalyst after vowing to never install it again.
I've got artefacts all over the screen, even during post. I've tried using the Asus flash utility. That doesn't do anything. I've managed to uninstall Catalyst but whatever it's done to my card is stuck.
I've reinstalled Catalyst but it wont start as it won't recognise the card. Says the driver is incorrect (even though the driver is installed at the same time)...
I think I need to flash the 4850 bios unless anyone has another suggestion?
I have a USB stick with DOS on it which I've used to flash the motherboard bios with. I'm a bit concerned that I can't seem to find the actual bios to flash!
Any help out there?
Any help out there?
