I have a Athlon 3200+ on a GA-7N400 pro2 mother board with a Radon 9800 graphics card and I am looking to get water-cooling to cover CPU, GPU and front side chips. All of the kit is running at standard speeds and I just want to get a quite pc.
My questions are:
Will all the be able to be cooled with one 120mm radiator?
Is it best to buy a kit or seperate componants?
I am looking to do this cheep as is possible so what kits/componants would people recommend and where to buy from?
How hard is it to put together and bleed a system?
Thank you, James
My questions are:
Thank you, James
) and buy a componnent every couple of weeks to spread the cost out
