Hi all, first of all im sorry for creating a thread like this but i couldnt really help my friend with this so i thought id ask here.
He needs some help on creating a Machine code using DOS that adds up the decimals 43+54 and displays the answer on the screen as a single character. It should scan the keyboard and if you press "n" the program should display my name.
If i press x then the program should return me back to the DOS prompt. If any other key is pressed then it should rescan keyboard.
Thanks a lot
Thanks a lot
