Help for newbie with laptop
30 Jun 2005
:o
Need some help folks.
Just bought a new Asus A7J laptop and i wanted to update windows and the rest of the programs.
I've unplug the rj45 cable from my pc and plug it in the laptop then restarted.
All i get is "limited or no connectivity" after that. Do i need to restart my NTL modem then plug it in the laptop?
Totally Lost!!!
thanks for any tips.....
Yes you do. Whenever you plug a cable modem into a different device you'll need to power it off and then power it back on again.
