Hi all
I am out of my depth but here goes!
My daughter would like to play sims 4. i have run my laptop thru "can you run it" and it said no. Results are below.
Is there anything i can do to make this work on my laptop or is it not good enough?
I'd appreciate any advice - thank you
Video Card VIDEO CARD
Minimum: NVIDIA GeForce 6600 or ATI Radeon X1300 or Intel GMA X4500
You Have: Mobile Intel(R) 4 Series Express Chipset Family
Video Card Click here for the latest Video Card drivers.
Upgrade Suggested
8th percentile
Features: Minimum attributes of your Video Card
Required You Have
Icon Pixel Shader version 3.0 4.0
Icon Vertex Shader version 3.0 4.0
Icon Dedicated Video RAM 128 MB 64 MB
CPU CPU
Minimum: Intel Core 2 Duo E4300 or AMD Athlon 64 X2 4000+ (2.0 GHz Dual Core required if using integrated graphics)
You Have: Celeron(R) Dual-Core CPU T3500 @ 2.10GHz
CPU Click here for the latest CPU drivers.
Upgrade Suggested
1st percentile
CPU Speed CPU SPEED
Minimum: Info
You Have: 2.1 GHz
RAM RAM
Minimum: 2 GB
You Have: 3.1 GB
3.1 GB
19th percentile
OS OS
Minimum: Windows XP
You Have: Microsoft Windows 7 Home Premium Edition Service Pack 1 (build 7601), 64-bit
Windows Click here for the latest Windows drivers.
Free Disk Space FREE DISK SPACE
Minimum: 10 GB
You Have: 265.6 GB
Free Disk Space Click here for the latest Free Disk Space drivers.
Sound Card SOUND CARD
Minimum: Yes
You Have: Realtek High Definition Audio
Sound Card Click here for the latest Sound Card drivers.
Upgrade Suggested
8th percentile
Required You Have
CPU CPU
Upgrade Suggested
1st percentile
CPU Speed CPU SPEED
Minimum: Info
You Have: 2.1 GHz
RAM RAM
Minimum: 2 GB
You Have: 3.1 GB
3.1 GB
19th percentile
OS OS
Minimum: Windows XP
Minimum: 10 GB
You Have: 265.6 GB
Minimum: Yes
