ok this is starting to get annoying....
my system runs stable as a rock with these settings...
BLCK 200
Vcore 1.3
QPI-VTT 1.33
QPI Link X36 at 7.2ghz
RAM at 6X 1200mhz
Unicore frequency at 13X run at 2.6ghz
however the ram is running blow rated clockspeed when i ramp up the ram..
8X at 1600mhz
and raising the uncore frequency to 3.4ghz
setting the DDR voltage at 1.5v
the system becomes unstable and fails in the second pass in Intel Burn test..
so its deffo the RAM do you recommend that i increase the ram voltage or am i making a mistake with the uncore frequency as i take it uncore should be X2 your ram speed....
thank you for any suggestions....
BLCK 200
Vcore 1.3
QPI-VTT 1.33
RAM at 6X 1200mhz
8X at 1600mhz
