Help from the Blackberry experts please!
30 Jul 2008
I've just got a Blackberry Torch and every time I plug it into the PC via USB it immediately starts charging instead of giving me the option to select mass storage for instance.
I can't see the Torch in my computer at all. I believe i'd need to enable the mass storage option before I can transfer any files to it. I know the USB cable is working due to the device charging as soon as its connected so does anybody know how to enable mass storage mode?
I don't get any pop up box at all. :(
Settings>Memory Mass storage support
Is this an option in BB OS 6? I can't seem to find it using the path you've provided.
I can't find anything to enable mass storage or that dialog box that should pop up when I connect via USB. Admittedly i'm new to this whole OS. :p
All sorted! Seems the micro USB was only good for charging!??
If anyone else has similar issues in future, try another USB cable. :)
Do you have a PS3 by any chance?
I got the cable used to charge the PS3 controllers, and my Berry mixed up, with exactly the same problem!
