HELP!! GA-P35-DS4 BIOS crisis!!
20 Nov 2007
I've just finished a new build with a GA-P35-DS4 mobo. Everything appeared to be working (at least from within BIOS) so I tried to update the BIOS before I went any further.
That seemed to go ok too but now the damn thing won't boot at all. It comes on for about 20 secs then just restarts and goes through the same cycle indefinetly. No sign of life in the keyboard, nothing happens on the monitor at all. Plugged in an old speaker and it sometimes posts but just 6 short beeps then dies on the 6th.
Can anyone please help!!?
Cheers, Andy.
I checked the m/b book, it has the error codes in, there's nothing for six beeps.
1long 3 short is keyboard
continous long beeps is graphic's card
............. Short beeps is power error
1long 9 short bios rom error
Be surprised if its power, seems a big coincidence that it was immediately on updating the BIOS. Its definetly six short beeps every time but I can 't find anything about the error code either
Was it ok on the old bios?
If so why not just go back to the old bios, could also try swapping the ram to make sure the other stick works.
It may well have been ok with the old BIOS, it looked ok without going as far as installing an OS or formatting discs, just seemed sensible to update the BIOS at the beginning :s
If there was a way of going back to the old BIOS I would but it doesn't appear to be dual bios so :(
(Removing the CMOS battery didn't help)
I'm on my 2nd GA-P35-DS3P , the first did what you're describing but NOT after a BIOS flash.
Basically the PC did a Vista BSOD , BIOS message said something about BIOS recovery :confused: , it rebooted , ran for 5 minutes then another BSOD. After that it just looped around , switching itself on / off every 5s (ish). I tried removing everything / reseting BIOS etc but it was snafu.
In the end I phoned up those very nice people at OcUK , got a RMA number & sent it back. It was confirmed as a dead-un and they sent me a new one by the end of the week .
The DS4 should be able to recover from a bad BIOS flash due to its dual BIOS thingy.
Have now tried all the above (battery out, different RAM modules etc.) but no success yet.
Don't understand why the 2nd BIOS isn't kicking in and allowing recovery, very odd. Screen just stays completely dead, not even kicking the monitor back into life from standyby. Emailed Gigabyte and they told me if the CMOS reset doesn't work then its back to sender :(
No christmas meddling for me then.
You did use the right bios? There's 3 versions of the bios for the boards, v1.0, v1.1 and v2.0 I think.
My board is v1.0
