I got a gainward GTX295 and noticed theres a pciexpress power connector and then another 8 pin one. my corsair 620hx has no such power connector and the gtx manual seems to suggest there is some sort of power splitter that plugs into the card and then a normal power connector off the psu. However no such power splitter cable came in the box.
my psu also has 2x pcie power connectors and one of them will fit on the right hand side of the 8 pin connector on the card, leaving the left 2 holes empty but this did not work either. all i get when i turn it on s a long beep and 3 shorter beeps from the mb, and no display at all.
should there have been some sort of power splitter connector cable in the box? there is space for something like that in the polystyrene cutout so i think it may be missing but the manual is not clear about whether it needs it or should have it, or not, and neither the box or manual gives an included parts list.
