As per title i could do with some help getting my oc a bit further.
rig:
q6600 G0, xfx790i ultra mobo (latest bios p04),
2x2GB ddr3 ocz 1333 cas 7,
8800gtx's in sli
zalman 9700 tritium cpu cooler
coolermaster cosmos S
etc etc..
anyway VID for the 6600 is 1.325V which i know is quite high
currently clocked to 3.15GHz
rated fsb = 1400mhz = 350mhz*9
this at 1.475V in bios - 1.440 in windows idle and 1.400V full load.
any less and prime gives rounding error on core 2.
i've never seen core temps above 58 on load so would like to push it abit further if i could.
i've left nb(spp)/sb(mcp)/fsb voltages on auto atm, which adjusts them to 1.35/1.5/1.4 respectively.
which is stable
anyway my problem is that if i even nudge the rated fsb to 1401mhz the system hangs on reboot pre-post,
and then i have to jump the bios and start again
thought it could be an fsb hole, but i've taken it up through 1466 (3.3GHz) right up to 1600 (3.6Ghz) but
it just wont post.
oh and the memory is being left at stock atm.
i'm fine with it running at 3.15 but you know how it is
suggestions welcome
cheers
rig:
8800gtx's in sli
etc etc..
which is stable
it just wont post.
suggestions welcome
cheers
