I've got a Li-Lian PC-7 Plus II with the two 120mm stock fans installed, a Tuniq Tower 120 CPU Cooler, a 8600 GTS GPU, and a Gigabyte GA-P35-DS3 mobo. It's noisy as hell.
The biggest source of the noise seems to be coming from the stock system fans that came with the case, mainly the exhaust fan in the back which seems to be spinning at max at all times. I can't seem to find any options in the bios to cut the voltage down for the fans.
Anyone know what I could do to get these fans to slow down, or should I replace them with something more quiet.
