Help getting iSight camera working on Parallels 6 latest version with a W7 Pro machine!
8 Jun 2006
Hertfordshire
Hi Guys
I've install the latest version of Parallels 6 and have a Windows 7 pro virtual machine running perfectly.
I cannot however get the iSight camera to work under Windows 7, I have read allot on the web and tried installing the driver under W7 and it say's its installed fine but if I restart the W7 machine the camera vanishes from device manager again :(
I've loaded the drivers from the Snow Leopard DVD also and this also does not work..
Has anyone got theirs working in the same or similar setup and can offer some advice, I've exhausted all the web searches ...
Many thanks
Mart
I've got mine running on a win7 x64 install on P6. Although the iSight device comes up as drivers not installed, I can go into MSN and use the camera for vid messaging.
The drivers were loaded from the Snow Leopard CD under:-
CD:\Boot Camp\Drivers\Apple\x64
If I restart the VM, the cam is still available and usable.
Hmm
I'll try it again with the dvd then..
Spoke to support today and they only gave me a fix I had tried and failed with before..
