hi just looking to see if anyone would be able to help me out. i just built a new system for work as the old pc was around 10 years old maybe even older so i decided to upgrade it to a i5 2500 with a asrock h61m dgs mother board
the problem i am having is that i cloned the old hard drive using Macrium Reflect and when i try to boot with with the new drive in the new pc i get stuck on a error screen saying the pc wasnt turned of properly the last time it was used this message keeps coming back after hitting enter so its stuck in a loop.
if i put the new drive in the old pc everything works fine so im guessing that some of the old drivers is conflicting with my new hardware is there anyway round this? as their is a lot of very important information on the drive ie business invoices and accounts that i need also the business program called quickbooks which i also need transferred onto the new ssd.
the os is windows xp if this helps
