Help GPU/Monitor Problem after build
2 Jan 2014
Hi All,
I changed my case from a Gamemax Sapphire to a Lian Li Dynamic XL due to some problems with heat dissipation and my 2080ti.
After a grueling 6 hour build I managed to get everything installed and I am facing a number of problems, one of which is my 4K monitor and GPU.
When booting up the computer with the two Displayport cables plugged in, which is how the Acer Nitro delivers 144hz the Monitor turns on flashes and the switches off(No Signal). If I boot down and turn the PC on with just one displayport cable plugged in it boots up fine, I can then plug in the second displayport cable and the monitor works fine and changes from 120hz to 144hz and I can resume as normal.
The montior and GPU worked perfectly fine before I switched cases.
Any Idea's what might be happening.
Sorry, I am a dummy. The main output has simply changed to DP2 instead of DP1, because I had the monitor set to stay on DP1 to stop the annoying screen changes at boot when I removed the second cable (D2) it did not show a signal.
