help, graphics card flash gone wrong
6 Nov 2004
Hi i just flashed my x1800xt to higher clocks, but i think the clocks were too high.
Now when i restarted it wont even start, the screen is black there is no beep to verify all is ok and the fan is on 100%, i think the card itself is actually 100% fine but the bios clocks are too high, ive got a backup of the old bios on the floppy drive but how do i get it onto the card?
Is it possible to stick a graphics card into the 4X pcie slot, boot it up run the screen of that and flash the bios onto the x1800xt in the 16Xpci-e slot that way?
or will that accidently flash the card in the 4X pcie slot?
i dont have a pci gfx card lol, will it not work if i stick my card in the pci-e 4X slot?
where can i get a cheap crap pci card from today?
You're going to have to blind flash it if you can't get hold of a PCI card, this site is mainly Nvidia based but will steer you in the right direction on how to do it.
