help. graphics card overhangs n.bridge fan and stops it spinning
Just try woggling the card out a tiny bit to get a little extra space, works fine for me.
Also take the oval cover off the NB heatsink.
Lemonsquokey said:
Tried that still no joy. ****** hell.
will the graphics card work in the other pce-e slot until I can find a remedy?
Please edit the sweary. The bottom slot is fine, you need to switch the SLI jumpers to get the bottom slot from 2x to 8x.
