[Help] - Graphics / Login Page
16 Jun 2013
Lol yeah sorry I didnt catch it quick enough. For some reason PS isnt allowing me to save the colour changes and it reverts back to a completely different one.
If I use the RGB decimal version of AE322C it saves fine. Updates the image links.
I thought it looked wrong so had to double check and I noticed the screw up.
16 Jun 2013
I can indeed if that's easier for you.
I'm not sure why the background has changed colour.
To be fair you can easily do this in gimp I only have photoshop as I was given a liscense for CS6.
16 Jun 2013
I had no idea either to be honest. Took me a while to notice it. Spent ages staring at it on my screen wondering what gray you were on about :D.
Is that what you're after or do you need it changing further?
