Help Grathics card will not display after powercut. msi 6970 lightning
1 Apr 2010
Hello Hoping one of you may be able to help me out here.
my card was running perfectly fine yesterday but this morning at around 7am there was a power cut. i tried turning the system back on everything appears to boot up hear window's sounds etc yet i do not get a display to the screen.
the Cables are detected and such but the screen remains black.
i have tried putting the card into my brothers system and i get the same issue. My computer get's a display when using a old gcard i have laying around yet the 6970 fails to display.
i have tried everything i can think off but it is looking like i will need to replace it as the warranty is gone on it Manufactured in 2011/08.
Is there anything else i can try with the card before i make the jump with buying a new card?
Here are some pictures incase i missed something.
https://www.dropbox.com/s/fber7njtro6k4ww/WP_20140414_15_51_55_Pro.jpg
https://www.dropbox.com/s/cghqtro7mn76ott/WP_20140414_16_01_06_Pro.jpg
https://www.dropbox.com/s/dl66z90ezaje52f/WP_20140414_15_51_24_Pro.jpg
Many Thanks
Please can you let us know how your rma goes, how easy it was, how much it cost you to send it back and how long the whole process took.
Quick update i have gotten a invoice for my new card that is arriving shortly. which is a Sapphire Radeon R7 265 Dual-X now i am not too sure if that card is on the same performance level as my old MSI 6970 lightening 2gb was.
Could anyone help me out on this as i have some doubts if this new card is at the same performance level as my old one. I know its not no where near as overclockble as my old card either.
Thanks
Karl
