Hi all,
I've just built my new PC, everything was going smoothly until today, I have bought a new keyboard and mouse to go with the new set up, but I'm thinking it's probably a coninsidence.
I think I may have an electricity leak somewhere, my legs feel fizzy and achey and my PC is doing odd things, the sound has cut out.... intermittantly, the mouse and key board shift on and off and it varies depending on which port I'm using, front or back, then reset. And when I switch it off it reboots the first time then switches off the 2nd time.
Hmm... arms are knumb and heavy... gotta step away from the PC...
Is there any way I can find out where the problem is?
Thanks! <powering off for now, will check back intermitantly!>
Kit: Abit P35 Pro with Q6600 + Artic Pro 7
4gb Corsair DDR2 6400
Asus lightscribe DVD
and a Samsung F1 750gb drive, two of my existing 150GB drives (WD)
Corsair HX520
And the OC 8800GTS
New Keyboard and mouse set: Logitec DiNovo Edge and MX Revolution
Corsair HX520
And the OC 8800GTS
