TomL said:You need to format the floppy disk first as a MSDOS boot disk, then install Memtest+ onto it.
ahh i just formated the floppy then installed memtest onto it
Thats odd, Ive just done a 24 hour memtest and simply formatted a floppy and extracted memtest onto it.TomL said:You need to format the floppy disk first as a MSDOS boot disk, then install Memtest+ onto it.
footman said:Thats odd, Ive just done a 24 hour memtest and simply formatted a floppy and extracted memtest onto it.
00NukE said:Cpu 1.38v and mem is set to 3.25v in bios Orthos would fail on my system until I gave the mem some more power.
P.S. all other voltages are set to default.
mines only at 2.1 and thats the max geil say it goes up tofootman said:Thats odd, Ive just done a 24 hour memtest and simply formatted a floppy and extracted memtest onto it.
Jokester said:Yeah that's all you need to do, the extraction program basically makes the disk bootable for you.
Jokester
Jokester said:
Jokester said:
TomL said:I used that before I used Memtest86+, a more recent program, and it found no errors whereas Memtest+ did.
