Help ! HL ep 2 DL stuck ...
14 Nov 2002
I have the Black box voucher, which valve still honour if it came with your ati card.
I entered the code and started to download, Portal and TF2 downloaded and completed but HL ep 2 reached 44% and hasn't moved since yesterday, tried deleting the blob file no difference.
A quick bit of research tells me I am not the only one, but if you have HL episode 1 it works fine .... now I have the original HL2 CD .. its installed and updated, so I assume ep1 is another download only content ?
Is it possible someone could gift me ep1 ?
Unless someone knows a fix that will get ep 2 downloaded for me ?
Hi smithy83,
That would be helpful and very public spirited of you :) ... unfortunatly I don't have anything I can gift back ... a guest pass for Counter Strike Surce, but I guess most people have that already.
I haven't used steam for ages, so not sure how it works ?
Anyways steam ID is: Majik19
is your steam id same as ocuk forum name ?
I got the been added pop up, but cant find you ... told you I didnt know how this works, apologies :o
Yes you can send it to my trust addy .. or try id of bartflaster ?
If that doesnt work send me an email. I have a link to the episode 1 .gcf files that you need. I had the same problem and downloading them worked for me.
