Today I got a Draytek Vigor 120 ADSL Modem (just a modem, its not a router). Im going to be connecting it to a router later.
Ive got Sky Broadband.
But, Ive been trying to rig up the modem to the PC to access the internet without a router for now. The Vigor has a single ethernet connection to the PC.
Ive connected all the cables up, it powers on, all LEDs come on. 'It says' its found the DSL connection with the green LED on solid, not blinking.
I log into the modem through internet browser and under status, its shows as being connected by PPPoA to the ISP.
But, when I try and go on the internet....nothing.
The instructions say it should work straight out the box with most UK providers. I does mention in the instructions about logging onto your ISP with your username and password ???
Up until now Ive been using the router issued by Sky (a Sagem F@ST 2504) and I've never had to put any user name or password to get onto the internet. Do I need to now with this new modem? Is the username and password built into the Sky router they supplied?
It's been ages since I used a non Sky router/modem.
