Help identify a part found loose in my engine bay...
18 Oct 2002
Birmingham
Found in a mk3 Mondeo 2.0 petrol.
The reverse has a 2 pin plug.
It's obviously (hopefully?) been replaced and the old one left lying where it shouldn't. All fluid levels are fine anyway.
I'm curious what it is if only so I can check there's a new one where it should be.
Do you have another plugged in?
Seems unlikely it would unscrew and unplug itself :D
Reverse lights work fine so must be.
From Googling it looks like a common failure so a previous owner/garage must have just switched it and left the old one lying around. Was just bothering me trying to figure out what it was :o
