Help identifying buzzing
21 Jul 2007
Newcastle upon tyne
Hi all,
Few weeks back I had recorded this noise coming from my computer. I cannot workout what it could be. The sound comes from the front right and was idle. But when the front right side panel is pressed a little it stops for a little bit then will start now and then. Also happens when under load also.
Got me stumped. I have rebuild the system and still getting the noise.
Any ideas
Thanks!
It's the casing or internal drive bays that vibrate enough to create a sound. My case does it as well or used to.
It will stop over time or you need to start wedging folded paper in things until it stops.
Or it could be a fan bearing.
Cheers guys, I think I will start with changing the front fans and see what happens.
Before you start changing the fans, check which ones are the culprits by carefully pressing the centre of the fan to temporarily stop it whilst in operation. If the sound stops or gets better, then it's the cause or partly the cause of the noise.
Thanks, well I did what you said and all fans are good. Now I am thinking it could be the HDD tray or a cable or even HDD starting to go.
100% that is not the hard drive mate, sounds just like a cable caught in a fan or a bearing. If it's not the fans are you certain a cable isn't touching the blades? Could it be from the power supply!
I believe it's a fan. Some fans may do it when 100%, but I had fans that were doing similar noise at 50% when the same model/"batch" would be fine but increasing the speed a little bit, other fan would do it and the one doing it at 50% would stop.
Try disconnecting all fans and plug one by one.
The worst scenario would be the panel vibrating, that can be sorted, but it's more complicated. I've used silent coat, yes, the stuff for car, and worked.
Only connect the bare minimum components (e.g. only CPU fan, no HDDs, etc), to see if the noise persists in BIOS. If there's no noise, then shutdown and add one piece of hardware at a time until you find the culprit.
Just added you on Steam mate, if you need some help.
Thanks I will keep you posted
Thanks guys that was going to be my next question about how to go about it
Check it's not the gpu
Check it's not the psu
Otherwise is say it's something catching a spinning fan, or power supply components on the mobo.
Do you have a watercooling?
