Hi guys. I built my PC just over a week ago.
AMD Athlon II X4 Quad Core 635 2.90GHz (Socket AM3) - Retail 1
Patriot Viper 4GB (2x2GB) PC3-10666 1333MHz Dual Channel (PVS34G1333ELK)
Asus M4A78LT-M LE AMD 760G (Socket AM3) DDR3 Motherboard 1
Corsair CX 400W ATX Power Supply (CMPSU-400CXUK) 1
Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache - OEM (ST3500418AS) 1
Xigmatek Asgard Midi Tower Case - Black 1
Samsung SH-S223C/BEBE 22x DVDąRW SATA ReWriter (Black) - OEM 1
Here's exactly what has been happening:
I'll boot the PC up in the morning and after loading Windows 7, applications will stop working (Firefox, IE, CCleaner, etc.) and then I'll receive a BSOD. This will continue for many times but then the computer will work fine for 12 hours or more. Then as soon as I start the computer the next day, this cycle continues.
Here are the error messages just from today:
So far I have:
Reinstalled Windows 7
Ran memtest for 12 hours - no errors reported.
Ran orthos/Prime95 for a few hours - no errors reported.
Contacted OCuk support - told to run these applications again.
Would highly appreciate your help. Very frustrating!
On Tue 03/08/2010 14:03:51 your computer crashed
This was likely caused by the following module: ntoskrnl.exe
Bugcheck code: 0x4E (0x99, 0x93169, 0x1, 0x93CC1)
Error: PFN_LIST_CORRUPT
Dump file: C:\Windows\Minidump\080310-18298-01.dmp
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
The crash took place in a standard Microsoft module. Your system configuration may be incorrect, possibly the culprit is in another driver on your system which cannot be identified at this time.
On Tue 03/08/2010 14:01:08 your computer crashed
Bugcheck code: 0x4E (0x99, 0x9CC68, 0x1, 0x9CC70)
Dump file: C:\Windows\Minidump\080310-17706-01.dmp
On Tue 03/08/2010 13:57:29 your computer crashed
Bugcheck code: 0x4E (0x99, 0xCC3F0, 0x2, 0x10380F)
Dump file: C:\Windows\Minidump\080310-24944-01.dmp
On Tue 03/08/2010 13:55:29 your computer crashed
Bugcheck code: 0x1A (0x5003, 0xFFFFF780C0000000, 0x1AB9, 0x1A8C00043572)
Error: MEMORY_MANAGEMENT
Dump file: C:\Windows\Minidump\080310-18205-01.dmp
On Tue 03/08/2010 13:53:00 your computer crashed
Bugcheck code: 0x4E (0x99, 0x8D1C6, 0x1, 0x8D1CE)
Dump file: C:\Windows\Minidump\080310-18252-01.dmp
On Tue 03/08/2010 13:51:02 your computer crashed
Bugcheck code: 0x4E (0x2, 0x70F58, 0x12FFFF, 0x1)
Dump file: C:\Windows\Minidump\080310-17862-01.dmp
On Tue 03/08/2010 13:45:35 your computer crashed
Bugcheck code: 0x1A (0x41284, 0x7FEFD011001, 0x0, 0xFFFFF70001080000)
Dump file: C:\Windows\Minidump\080310-20514-01.dmp
On Tue 03/08/2010 13:44:04 your computer crashed
This was likely caused by the following module: ntfs.sys
Bugcheck code: 0x24 (0x1904FB, 0xFFFFF88006D211E8, 0xFFFFF88006D20A50, 0xFFFFF880012EC173)
Error: NTFS_FILE_SYSTEM
Dump file: C:\Windows\Minidump\080310-20124-01.dmp
file path: C:\Windows\system32\drivers\ntfs.sys
description: NT File System Driver
On Tue 03/08/2010 13:42:19 your computer crashed
Bugcheck code: 0xFC (0xFFFFF8800124D05F, 0x8000000003968121, 0xFFFFF88006E6CEB0, 0x2)
Error: ATTEMPTED_EXECUTE_OF_NOEXECUTE_MEMORY
Dump file: C:\Windows\Minidump\080310-21340-01.dmp
So far I have:
