I have an issue with an instrument cluster, there are two push buttons, the 'select' button appears to be stuck in the depressed position as far as the cluster is concerened. The button still 'clicks' when pressed and released, though it's an audibly duller click than the 'reset' button which is the same button type.
I'm thinking the button may have failed mechanically, and simply replacing it would fix the issue, as there doesn't appear to be anything obviously burned on the board, and no water damage. The issue I'm having is identifying the button so that I can source a replacement. Not sure if this is the best subforum to post this in, so apologies if there is a better one that I missed.
The images are quite large, so they are in a spoiler tag below. 'SW1' is the problem button / switch.
