I noticed when I moved my car earlier that it left a wet patch on the block paving. At first I thought nothing of this. I'd had the air con on and thought it would just be water dripping off the air con pipes.
However, after an hour or so it hadn't evaporated so I then thought perhaps it would be oil.
I've moved it onto the road to stop it marking the paving, but am pretty sure it's not oil.
I've found the point under the car it seems to be coming from and taken a few pics, I wonder if any mechanically minded folks could take a peak and see what they think. Is it likely to be something serious, or safe to drive the 20 or so miles to get get home (I'm at a mate's house).
The fluid looked a really bright orange when I got some on my hand, but unfortauntely when I came back to take a pic most the bright orange stufff had gone leaving just a residue that you can't really tell the colour from the pics, but it's definately orange ish... I wonder if it's the same as the fluid in the expansion tank (pic taken for comparison).
Any ideas? Thanks.
You can see in this one it seems to have stained an orangey/purpley colour as it has dried.
How it's dripping onto the road (I should add it isn't exactly gushing out, just the occasional drip - it was parked there about an hour and that little patch on the road is all there is)
Expansion tank - it's parked with the wheels on the curb so it's hard to tell the level from the pic, but it's about midway between min and max.
Any ideas? Thanks.
