Help Identifying Lock
28 Mar 2005
Drunken badger punching
It's old, worn and rusty and secures the site door of my garage. It needs to be replaced. I can't find another lock the same and don't know what to type it is which doesn't help.
It's made by Legge and that's about all I know:
Any ideas? I'm hoping to find the same sort of thing so I can mount it to the existing door structure. For reference it measures 110mm x 70mm.
Type of VERTICAL rim lock.
Could replace with a Sash lock, if you can find one with the fixing holes.
Will sort another pic tomorrow. Can't find anything that would be a suitable replacement as yet.
