Hi,i need an x99 mobo that can accept 2 660ti's and a SB zx pci-e,i was looking at the asus x99 as i normally only use asus boards,but from what ive seen in reviews and youtube is that when you use 2 gpu's they block off the smaller slot I need for my sb.
Ive seen theres a little switch that you use to change gpu's between1,2,3 way and illuminates the slots to use,but can you choose which slots are used in 2 way to make sure the smaller slot is free?.
If not I need a mobo that can run 2 gpu's and a sb and some ram to match the board,id be gratefull for any help
cheers.
P.S I was looking at ddr4 2666 I wont be overclocking id just like stability
.cheers.
