Hi all,
Challenge: Better wireless throughput / range vs sky Q box. Also need ability to block individual devices during certain time periods or as and when required.
The sky q box is really struggling to handle all our requirements. it's a 40mb fiber line but I sometimes find that it's quicker using 4g on my mobile than our wireless connection! I've installed some powerline adapters upstairs with cat 6 cabling to support 4 xbones, 2 laptops, 2 desktops, as well as having 5 mobile phones hanging off of the sky q's wireless.
Overall there are 20 devices that need internet access of which I would say 14 would be in use at the same time. Ideally I'd like to reduce the number of powerline adapters and move over to wireless but I'm not sure if this would end up just straining the router and causing the wireless to slow down to a crawl.
I'm not prepared (read: my Wife is not prepared) to run cable around the house sp I have been looking at linksys wrt1900acs as well as the 3200acm as a possible solution but am not sure if these would be a wise choice.
Any suggestion would be appriciated.
thanks!
thanks!
